Hello
Could someone help me with clip volume settings. I want to set Drawing seed to none. Refer below image. Thanks
If you really do not want to see these Drawing Seeds, then you could try adjusting/editing the variable MS_DRAWINGSEED_LIBLIST and point it to an empty DGNLib file for example. However, this will also affect the Detailing Symbol tools, there will be no drawing seeds available there either.
For more on Drawing Seeds, see the article about Drawing Seeds in DGN Libraries
