Is it possible to import geotagged images into a dgn-file? Having the images land where the geotag location is? I measured a pipe, and took pictures if the pipe-labels along the way. I'd like these images to show up at the correct location in Microstation. The topics I've found on this date back to 2012, so I was hoping an update had made it possible.
I still would try : l GPSPhotoCells: www.centauron.de/.../katalog.dot
It's a professional supported product.
Frank
