I have changed my OS to windows 10 but unfortunately I got back same graphic problems I had when I installed powerdraft, the drawings are all jammed together. Would appreciate any suggestions. Sorry I know WINDOWS 10 is new but I believe Bentley has been preparing its launch for sometime.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Andres Lozano said:Where can I find that QV_D3DVERSION?
It's a Windows environment variable that you set using Windows tools. If you search the web for QV_D3DVERSION you will find several results that instruct you what to do.
