[V8i] Sheet Displays Differently From Model
Hi all,
I'm working on 3D pit & pipe road drawing which is to become an xref for a client. It's an ACAD drawing, however being modified in Microsation V8i
In order for the client to more easily review the design, lengths of the road have been set up as sheets. At some point in the last few days three of the eleven sheets have begun to display so that the conduits now appear in the middle of the road, but only on the sheets, it's as if the background reference has shifted up in three views. The model isdisplaying as it should!
I've checked levels in the sheets, but all of the levels are displayed. I have also tried using the correctly displaying sheets to recreate the three sheets, but the same issue happens as I pan the view along the road to create the sheet. Unfortunately extensive changes have been made to the design since it was noticed, so it's not just a simple matter of retrieving the file out of archive.
I'm stumped.
Parents Reply Children
