Hello everybody, I am trying to draw a piece with a circular face and a rectangular face and I don't know how I could do it. The piece is this
Thank you very much for your help.
Luis.
Under Tools-->Surfaces-->Create Freeform Surfaces you will find "Loft Rectangle to Circle." This will create a surface that can be turned into a solid using "Convert to Solid." tool.
Answer Verified By: Luis
I am trying to draw this exact. I can only get the rectangle to align to the centre of the circle though... How do we offset it?
Uncheck the Orthogonal:
If this answer your question please mark my answer verified.
José
So simple! Thank you for your reply. Appreciate it
