I have a dgn file with many (200) levels, that i need to split in to one single dgn file pr level. Would that be possible to do in plane microstation ?
From what it sounds like you are describing, you could create a "script file" that starts with a list of all the levels and then adds in steps to isolate each level and (using a fence) save that out. Something like this:
active level "text" of=* selview 1 place fence allfiles selview 1 fit view extended 1 ff="textDGN" selview 1 on=* selview 1
The above example sequence assumes the level (text) has something on it and uses view one throughout the sequence. You can use that as the "template" for your specific file, which you would need to iterate for each level. You would also need to determine what each filename is that you want to create -- "textDGN" is just an example here... that gets saved to MS_DEF. Further, you can concatenate all that into one statement (each "command" separated by a semi-colon):
active level "text";of=*;selview 1;place fence allfiles;selview 1;fit view extended 1;ff="textDGN";selview 1;on=*;selview 1
Answer Verified By: helgeh
First off run the compress function from File > compress> options select all then run compress design
This will help get rid of unused levels
now from the level manager > export
This will give you a csv table you can manipulate to extract all the level names
you can then use this to create the above script mentioned by phil earlier post, over and over using excel to change which level is on next and what to call the new file
then export this out as a script file..then run the script
but personally I would just use the level manager by hand to scroll through the lelves and level display manager to turn all off . set first level on, then
us this keyin
fit view extended;%d; place fence design;%d;sf=
( which I would add to an F key say F1 just for this job... put back to help latter or make a new F key menu and edit that)
Then once I have the right level on, run the F key use the levelname thats on to name the export and save out the contents
( SF= removes all in fence to new file where FF just copies contents)
Then delete the level from levelmanager
and make the next level on and repeat the F key to extract the data and repeat the process
If I had to do this for many files then yes I write a script for each one using the extracted level names...
Even with 200 level names I think I could do faster manually for one file and F key rather than writing the script for one file...
Lorys
Hi Phil, that was quick!=) I don't want to take to much of your time, and do not have access to the project from home. But if you could show me on the small sample I sent you ( layer 1 to 4), then I could try it out myself and on the project tomorrow. I will also need to know where I run it from in microstation, is it in the key in browser. Thanks!
LEVEL1-4test.xlsx
