Help With Command Level: Set Target
Hi all
I was wondering if someone could explain the use of a command in MS called Level: Set Target.
I am in the process of learning the different commands and currently covering the topic of Levels.
The Help manual is not very good and I was wondering if anyone knew how you would use this command.
