Problems with MS SS3 crashing when trying to place angle dimensions....each time I try to place a dimension using the angle between lines Microstation crashes. Anyone else having similar problems?
Hello, could you please describe your workflow in creating the dimensions. Please provide an example file with this issue for testing. This article may also help you: communities.bentley.com/.../10687.place-dimensions-between-parallel-curves Regards Derval.
