When I attach a material to a slab, with different Variables attached to it, so I can change properties later, it changes to a smart solid. In this case the variables doesn't work anymore.
Is this a bug / is there a work method where I can attach materials while the object stays a slab?
Regards Louis
Hi Marco,
Yes, I used a Seed file file from the delivered Connect Edition Workspace. In the movie attached to this message you can see the workflow.
Thanks in advance.
Attaching materials to individual faces (as opposed to the entire element) has to promote the Type 19 slab element to a SmartSolid, the simple primitive types can't support per-face material attachments. So if you had just accepted the element without picking a face it would not have changed it to a SmartSolid. If you really do want per-face material attachments, if you create a shape profile and extrude it to create a Parametric solid, then as Marco suggested you won't have this limitation. HTH -B
