I use text styles in which the color flag is not set, so I expect that when I place text the active color is used. When I open the text editor the active text style uses active color = as expected.However when I change the text style in text editor the color changes to white i.s.o active color.Is this new behavior in CONNECT?
Andre
Andrew,
No problem. Two screen captures with some explanation.
Initial:- Active Style = 1- Style does not have colour flag set, so use active colour (green in this example)- Start Text Editor -> Active colour is used, as expected
Next:- Change Text Style in Text Editor to St-3- St-3 does not have colour flag set, so use active colour (green in this example)- ! Colour in Text Editor changes to white !
