CONNECT Quick Access Toolbar edits not saving
I have created custom entries in my Quick Access toolbar by importing them from a V8i dgnlib file.
They imported fine, and they work. But I can't edit them after the import.
Can they be edited after importing them ?
Michael
  • Michael,
    It looks like you have uncovered a bug. When I edit the key-in I see what I believe is the same issue. What I see is the word (Pending) after the one entry I edited. What we should have seen is (Pending) also append to the parent split button. As a work around, If you go to the parent "Levels" split button entry and just add a random character to its labels, click out of the label you should see the (Pending) label added to it. If you then remove the character you just added and hit apply, I believe all your edits will be saved. The issue is, the entire split button definition needs to be updated and we are not currently setting that flag properly.
    We will log a defect so this issue is addressed in the next release.
    -Bill
