Help says that Items can be attached to Element Templates. I just gave a try and it seems not working - there is no action when I select Item. Can someone confirm this functionality works? Video attached.Thanks, Krzysztof
Krzysztof,
Do you have dgnlib with Items attached or have you defined some items in active dgn file?
I can attach item to element template. However command behaviour is odd, sometimes I need to close and open Element Template dialog to have it working.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
Answer Verified By: Krzysztof Burdziel
I guess there is no Item Types present in the active file or existing DGNLIB referenced.
Regards,Leonard Jones.
