This started in the EAP forum but could someone at Bentley confirm when the steel utility is to be upgraded to work with CONNECT?
stuartw said:Users have to go to previous versions of MicroStation...
You've already told us, in a previous post, that your organisation is unlikely to upgrade to CONNECT in the foreseeable future. You can carry on using MicroStation V8i and the steel utility without losing sleep over its absence in CONNECT.
