Problem Installing Microstation CONNECT Edtion
I tried to install Mircostation CONNECT Edition using the wizard but there is an error message saying "Check internet connection and restart the setup"
My internet is working fine and can connect to Bentley.com, etc. There is no proxy on my network. My colleague installed the software without problem even we are on the same network.
Any help is appreciated and I have attached the log file that was generated by the wizard.
By the way I do have Microstation Selectseries 3 on my machine and is working fine and is connected to Bentley.
MicroStation_CONNECT_Edition_20150909141505.log
[18AC:0F34][2015-09-09T14:15:05]i001: Burn v3.8.1128.0, Windows v6.1 (Build 7601: Service Pack 1), path: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe, cmdline: ''
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]MicroStation\ActivationWizard.exe'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeInstallFolderSuffix' to value ' 10.00.00.025'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\MicroStation CONNECT Edition\'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;OrganizationDirectory;WorkSpacesDirectory;WorkSpacesLabel'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;OrganizationDirectory;WorkSpacesDirectory'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{DB956E9F-5699-40DE-BA52-0985F8B2505A}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeBundleCulture' to value 'en'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeBuildType' to value 'Release'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeBundleShortName' to value 'MicroStation'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_MicroStation_en.zip'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{B5DCA1F0-25C2-467A-9FAB-0CA4A25F3ABA}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{EBF4A592-A779-4CC4-95D3-380537144BF3}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_MicroStationDocumentation' to value '{721EB971-B10C-36FA-92D7-604EFA706ACF}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnPreviewHandler' to value '{264B522D-1B7F-4AAF-A32B-55A6BF5679F2}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx64' to value '{BBD53DF6-15BC-3A1C-9E57-AC7291BA12D2}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx86' to value '{712D2EBD-E590-321F-9754-2C533C7C5508}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AAB6451D-BE58-4ABD-BFB0-797C65AFC30B}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_VisualizationContent' to value '{CA467A36-38EC-3C3D-ACEE-BE27EAF062B7}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_MetroStationWorkSets' to value '{6D8E2404-9C2A-3661-BB8C-A3B18C199AD8}'
[18AC:0F34][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\MarkT\AppData\Local\Temp\MicroStation_CONNECT_Edition_20150909141505.log'
[18AC:0F34][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleOriginalSource' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe'
[18AC:0F34][2015-09-09T14:15:05]i052: Condition 'VersionNT64  > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
[18AC:0F34][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleName' to value 'MicroStation CONNECT Edition'
[18AC:0F34][2015-09-09T14:15:05]i000: Loading managed bootstrapper application.
[18AC:0F34][2015-09-09T14:15:05]i000: Creating BA thread to run asynchronously.
[18AC:1B50][2015-09-09T14:15:05]i000: BentleyBundle Version 08.21.03.52
[18AC:1B50][2015-09-09T14:15:05]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\MarkT\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1'
[18AC:1B50][2015-09-09T14:15:05]i000: Setting string variable 'BundleCurrentPath' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT'
[18AC:1B50][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
[18AC:1B50][2015-09-09T14:15:05]e000: Using Layout File : C:\Users\MarkT\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1\Setup.lyt
[18AC:1B50][2015-09-09T14:15:06]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
[18AC:1B50][2015-09-09T14:15:06]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,Configuration,FileAssociationFeature'
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCoreStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLangStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]e000: Failed for Package Id: VisualBasicLang2
Bootstrapper Application Data is not found for the Feature: VisualBasicLang2
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451FullStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClientStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackageStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeatureStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_ConfigurationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContentStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSetsStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]e000: Failed for Package Id: PowerProductLanguagePack
Bootstrapper Application Data is not found for the Feature: PowerProductLanguagePack
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandlerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvierStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporterStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
[18AC:1B50][2015-09-09T14:15:06]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:07]i000: Display is set to Full
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]i000: Register callbak=ProxySettingsPage
[18AC:1B50][2015-09-09T14:15:08]i000: Display Page=ProxySettingsPage
[18AC:1B50][2015-09-09T14:15:08]i000: Cannot Display Page=ProxySettingsPage
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
[18AC:0F34][2015-09-09T14:15:09]i100: Detect begin, 18 packages
[18AC:0F34][2015-09-09T14:15:09]i000: DetectBegin: Installed State of Package DetectedAbsent
[18AC:0F34][2015-09-09T14:15:09]i000: Registry key not found. Key = 'SOFTWARE\Bentley\BentleyDesktopClient\Install'
[18AC:0F34][2015-09-09T14:15:09]i000: Setting string variable 'NetFramework45Version' to value '379893'
[18AC:0F34][2015-09-09T14:15:09]i000: ReferenceId 63645=63645
[18AC:0F34][2015-09-09T14:15:09]i000: ReferenceId [VBA_LANGUAGE_PRGID_1033]=63644
[18AC:0F34][2015-09-09T14:15:09]i052: Condition '(NetFramework45Version >= 378758 AND VersionNT < v6.3) OR (NetFramework45Version >= 378675 AND VersionNT >= v6.3)' evaluates to true.
[18AC:0F34][2015-09-09T14:15:09]i000: ReferenceId 64771=64771
[18AC:0F34][2015-09-09T14:15:09]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.0.15' evaluates to false.
[18AC:0F34][2015-09-09T14:15:09]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i103: Detected related package: {454AD0FD-21D2-4E73-99E9-A40CAC75A636}, scope: PerMachine, version: 1.0.20.0, language: 0 operation: MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i103: Detected related package: {775616F7-2D4C-4D73-8773-A66C0BCECB38}, scope: PerMachine, version: 1.0.20.0, language: 0 operation: MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: VisualBasicCore, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: VisualBasicLang, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DotNet451Full, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: BentleyConnectClient, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: PowerProductPackage, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent
[18AC:0F34][2015-09-09T14:15:09]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent
[18AC:0F34][2015-09-09T14:15:09]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: PointTools32Extx86, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: MicroStationDocumentation, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnIndexer, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnPreviewHandler, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnThumbnailProvier, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnODBCDriverx64, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnODBCDriverx86, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: VisualizationContent, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: MetroStationWorkSets, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: UserAddedPackagesInstaller, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i000: Setting string variable 'BePlannedAction' to value 'Install'
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_WinTabFeatureAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductLanguagePackAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
[18AC:0F34][2015-09-09T14:15:09]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: RelatedBundle_Type=None; PlannedAction=Install
[18AC:0F34][2015-09-09T14:15:09]i052: Condition '(NOT BuildType_NotSameBuildType) OR Skip_BuildTypeCheck' evaluates to true.
[18AC:0F34][2015-09-09T14:15:09]i000: WixInstallBA::SilentPlan
[18AC:0F34][2015-09-09T14:15:09]i000: Cannot find Directory C:\ProgramData\Bentley\CONNECT Edition\
[18AC:0F34][2015-09-09T14:15:09]i000: AutoCad Civil 3D ObjectEnabler:Searching
[18AC:0F34][2015-09-09T14:15:09]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
[18AC:0F34][2015-09-09T14:15:09]i199: Detect complete, result: 0x0
[18AC:1B50][2015-09-09T14:15:14]i000: Setting string variable 'BeSkipFeatureConfigDialog' to value '1'
[18AC:1B50][2015-09-09T14:15:14]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair" AND NOT BeSkipFeatureConfigDialog' evaluates to false.
[18AC:1B50][2015-09-09T14:15:14]i000: WixInstallBA::Plan
[18AC:1B50][2015-09-09T14:15:14]i000: WixInstallBA::SetupModel Plan
[18AC:1B50][2015-09-09T14:15:14]i000: SetupModel::Before Plan
[18AC:1370][2015-09-09T14:15:14]i000: Before Plan Async
[18AC:1370][2015-09-09T14:15:14]i000: SetupViewModel::Before Plan
[18AC:1370][2015-09-09T14:15:14]i000: IsAnythingToDownload: Demanded by VisualBasicCore
[18AC:1370][2015-09-09T14:15:14]i000: ConnectAndUpdateDownloadSource: Connecting to BentleyServer for download paths
[18AC:1370][2015-09-09T14:44:24]i000: TryConnectingBentleyServer: NetworkException System.TimeoutException
[18AC:1370][2015-09-09T14:44:24]i000: TryConnectingBentleyServer: NetworkException The request channel timed out attempting to send after 00:01:00. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
[18AC:1370][2015-09-09T14:44:24]i000: IsAnythingToDownload: Demanded by VisualBasicCore
[18AC:1370][2015-09-09T14:44:24]i000: DisplayMessage (Installation failed with error code 0x0.)
[18AC:1370][2015-09-09T14:44:24]i000: DisplayMessage (Check internet connection and restart the setup)
[18AC:1370][2015-09-09T14:44:24]i000: WixInstallBA::Before Plan Complete
