Problem Installing Microstation CONNECT Edtion
I tried to install Mircostation CONNECT Edition using the wizard but there is an error message saying "Check internet connection and restart the setup"
My internet is working fine and can connect to Bentley.com, etc. There is no proxy on my network. My colleague installed the software without problem even we are on the same network.
Any help is appreciated and I have attached the log file that was generated by the wizard.
By the way I do have Microstation Selectseries 3 on my machine and is working fine and is connected to Bentley.
MicroStation_CONNECT_Edition_20150909141505.log
[18AC:0F34][2015-09-09T14:15:05]i001: Burn v3.8.1128.0, Windows v6.1 (Build 7601: Service Pack 1), path: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe, cmdline: ''
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]MicroStation\ActivationWizard.exe'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeInstallFolderSuffix' to value ' 10.00.00.025'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\MicroStation CONNECT Edition\'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;OrganizationDirectory;WorkSpacesDirectory;WorkSpacesLabel'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;OrganizationDirectory;WorkSpacesDirectory'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{DB956E9F-5699-40DE-BA52-0985F8B2505A}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeBundleCulture' to value 'en'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeBuildType' to value 'Release'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeBundleShortName' to value 'MicroStation'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_MicroStation_en.zip'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{B5DCA1F0-25C2-467A-9FAB-0CA4A25F3ABA}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{EBF4A592-A779-4CC4-95D3-380537144BF3}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_MicroStationDocumentation' to value '{721EB971-B10C-36FA-92D7-604EFA706ACF}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnPreviewHandler' to value '{264B522D-1B7F-4AAF-A32B-55A6BF5679F2}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx64' to value '{BBD53DF6-15BC-3A1C-9E57-AC7291BA12D2}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx86' to value '{712D2EBD-E590-321F-9754-2C533C7C5508}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AAB6451D-BE58-4ABD-BFB0-797C65AFC30B}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_VisualizationContent' to value '{CA467A36-38EC-3C3D-ACEE-BE27EAF062B7}'
[18AC:0F34][2015-09-09T14:15:05]i000: Initializing string variable 'BeVarProductCode_MetroStationWorkSets' to value '{6D8E2404-9C2A-3661-BB8C-A3B18C199AD8}'
[18AC:0F34][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\MarkT\AppData\Local\Temp\MicroStation_CONNECT_Edition_20150909141505.log'
[18AC:0F34][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleOriginalSource' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe'
[18AC:0F34][2015-09-09T14:15:05]i052: Condition 'VersionNT64  > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
[18AC:0F34][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleName' to value 'MicroStation CONNECT Edition'
[18AC:0F34][2015-09-09T14:15:05]i000: Loading managed bootstrapper application.
[18AC:0F34][2015-09-09T14:15:05]i000: Creating BA thread to run asynchronously.
[18AC:1B50][2015-09-09T14:15:05]i000: BentleyBundle Version 08.21.03.52
[18AC:1B50][2015-09-09T14:15:05]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\MarkT\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1'
[18AC:1B50][2015-09-09T14:15:05]i000: Setting string variable 'BundleCurrentPath' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT'
[18AC:1B50][2015-09-09T14:15:05]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
[18AC:1B50][2015-09-09T14:15:05]e000: Using Layout File : C:\Users\MarkT\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1\Setup.lyt
[18AC:1B50][2015-09-09T14:15:06]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
[18AC:1B50][2015-09-09T14:15:06]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,Configuration,FileAssociationFeature'
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCoreStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLangStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]e000: Failed for Package Id: VisualBasicLang2
Bootstrapper Application Data is not found for the Feature: VisualBasicLang2
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451FullStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClientStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackageStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeatureStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_ConfigurationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContentStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSetsStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]e000: Failed for Package Id: PowerProductLanguagePack
Bootstrapper Application Data is not found for the Feature: PowerProductLanguagePack
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandlerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvierStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporterStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Unknown
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
[18AC:1B50][2015-09-09T14:15:06]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[18AC:1B50][2015-09-09T14:15:06]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:1B50][2015-09-09T14:15:07]i000: Display is set to Full
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]i000: Register callbak=ProxySettingsPage
[18AC:1B50][2015-09-09T14:15:08]i000: Display Page=ProxySettingsPage
[18AC:1B50][2015-09-09T14:15:08]i000: Cannot Display Page=ProxySettingsPage
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[18AC:1B50][2015-09-09T14:15:08]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
[18AC:0F34][2015-09-09T14:15:09]i100: Detect begin, 18 packages
[18AC:0F34][2015-09-09T14:15:09]i000: DetectBegin: Installed State of Package DetectedAbsent
[18AC:0F34][2015-09-09T14:15:09]i000: Registry key not found. Key = 'SOFTWARE\Bentley\BentleyDesktopClient\Install'
[18AC:0F34][2015-09-09T14:15:09]i000: Setting string variable 'NetFramework45Version' to value '379893'
[18AC:0F34][2015-09-09T14:15:09]i000: ReferenceId 63645=63645
[18AC:0F34][2015-09-09T14:15:09]i000: ReferenceId [VBA_LANGUAGE_PRGID_1033]=63644
[18AC:0F34][2015-09-09T14:15:09]i052: Condition '(NetFramework45Version >= 378758 AND VersionNT < v6.3) OR (NetFramework45Version >= 378675 AND VersionNT >= v6.3)' evaluates to true.
[18AC:0F34][2015-09-09T14:15:09]i000: ReferenceId 64771=64771
[18AC:0F34][2015-09-09T14:15:09]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.0.15' evaluates to false.
[18AC:0F34][2015-09-09T14:15:09]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i103: Detected related package: {454AD0FD-21D2-4E73-99E9-A40CAC75A636}, scope: PerMachine, version: 1.0.20.0, language: 0 operation: MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i103: Detected related package: {775616F7-2D4C-4D73-8773-A66C0BCECB38}, scope: PerMachine, version: 1.0.20.0, language: 0 operation: MajorUpgrade
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: VisualBasicCore, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: VisualBasicLang, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DotNet451Full, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: BentleyConnectClient, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: PowerProductPackage, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent
[18AC:0F34][2015-09-09T14:15:09]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent
[18AC:0F34][2015-09-09T14:15:09]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: PointTools32Extx86, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: MicroStationDocumentation, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnIndexer, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnPreviewHandler, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnThumbnailProvier, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnODBCDriverx64, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: DgnODBCDriverx86, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: VisualizationContent, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: MetroStationWorkSets, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i101: Detected package: UserAddedPackagesInstaller, state: Absent, cached: None
[18AC:0F34][2015-09-09T14:15:09]i000: Setting string variable 'BePlannedAction' to value 'Install'
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_WinTabFeatureAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[18AC:0F34][2015-09-09T14:15:09]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: PowerProductLanguagePackAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Install
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
[18AC:0F34][2015-09-09T14:15:09]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[18AC:0F34][2015-09-09T14:15:09]i000: RelatedBundle_Type=None; PlannedAction=Install
[18AC:0F34][2015-09-09T14:15:09]i052: Condition '(NOT BuildType_NotSameBuildType) OR Skip_BuildTypeCheck' evaluates to true.
[18AC:0F34][2015-09-09T14:15:09]i000: WixInstallBA::SilentPlan
[18AC:0F34][2015-09-09T14:15:09]i000: Cannot find Directory C:\ProgramData\Bentley\CONNECT Edition\
[18AC:0F34][2015-09-09T14:15:09]i000: AutoCad Civil 3D ObjectEnabler:Searching
[18AC:0F34][2015-09-09T14:15:09]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
[18AC:0F34][2015-09-09T14:15:09]i199: Detect complete, result: 0x0
[18AC:1B50][2015-09-09T14:15:14]i000: Setting string variable 'BeSkipFeatureConfigDialog' to value '1'
[18AC:1B50][2015-09-09T14:15:14]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair" AND NOT BeSkipFeatureConfigDialog' evaluates to false.
[18AC:1B50][2015-09-09T14:15:14]i000: WixInstallBA::Plan
[18AC:1B50][2015-09-09T14:15:14]i000: WixInstallBA::SetupModel Plan
[18AC:1B50][2015-09-09T14:15:14]i000: SetupModel::Before Plan
[18AC:1370][2015-09-09T14:15:14]i000: Before Plan Async
[18AC:1370][2015-09-09T14:15:14]i000: SetupViewModel::Before Plan
[18AC:1370][2015-09-09T14:15:14]i000: IsAnythingToDownload: Demanded by VisualBasicCore
[18AC:1370][2015-09-09T14:15:14]i000: ConnectAndUpdateDownloadSource: Connecting to BentleyServer for download paths
[18AC:1370][2015-09-09T14:44:24]i000: TryConnectingBentleyServer: NetworkException System.TimeoutException
[18AC:1370][2015-09-09T14:44:24]i000: TryConnectingBentleyServer: NetworkException The request channel timed out attempting to send after 00:01:00. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
[18AC:1370][2015-09-09T14:44:24]i000: IsAnythingToDownload: Demanded by VisualBasicCore
[18AC:1370][2015-09-09T14:44:24]i000: DisplayMessage (Installation failed with error code 0x0.)
[18AC:1370][2015-09-09T14:44:24]i000: DisplayMessage (Check internet connection and restart the setup)
[18AC:1370][2015-09-09T14:44:24]i000: WixInstallBA::Before Plan Complete
  • MicroStation_CONNECT_Edition_140915.log
    [0C0C:05E0][2015-09-14T13:16:59]i001: Burn v3.8.1128.0, Windows v6.1 (Build 7601: Service Pack 1), path: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe, cmdline: '/passive'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]MicroStation\ActivationWizard.exe'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeInstallFolderSuffix' to value ' 10.00.00.025'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\MicroStation CONNECT Edition\'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;OrganizationDirectory;WorkSpacesDirectory;WorkSpacesLabel'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;OrganizationDirectory;WorkSpacesDirectory'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{DB956E9F-5699-40DE-BA52-0985F8B2505A}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeBundleCulture' to value 'en'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeBuildType' to value 'Release'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeBundleShortName' to value 'MicroStation'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_MicroStation_en.zip'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{B5DCA1F0-25C2-467A-9FAB-0CA4A25F3ABA}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{EBF4A592-A779-4CC4-95D3-380537144BF3}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_MicroStationDocumentation' to value '{721EB971-B10C-36FA-92D7-604EFA706ACF}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_DgnPreviewHandler' to value '{264B522D-1B7F-4AAF-A32B-55A6BF5679F2}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx64' to value '{BBD53DF6-15BC-3A1C-9E57-AC7291BA12D2}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx86' to value '{712D2EBD-E590-321F-9754-2C533C7C5508}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AAB6451D-BE58-4ABD-BFB0-797C65AFC30B}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_VisualizationContent' to value '{CA467A36-38EC-3C3D-ACEE-BE27EAF062B7}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Initializing string variable 'BeVarProductCode_MetroStationWorkSets' to value '{6D8E2404-9C2A-3661-BB8C-A3B18C199AD8}'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\MarkT\AppData\Local\Temp\MicroStation_CONNECT_Edition_20150914131659.log'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Setting string variable 'WixBundleOriginalSource' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe'
    [0C0C:05E0][2015-09-14T13:16:59]i052: Condition 'VersionNT64  > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
    [0C0C:05E0][2015-09-14T13:16:59]i000: Setting string variable 'WixBundleName' to value 'MicroStation CONNECT Edition'
    [0C0C:05E0][2015-09-14T13:16:59]i000: Loading managed bootstrapper application.
    [0C0C:05E0][2015-09-14T13:16:59]i000: Creating BA thread to run asynchronously.
    [0C0C:1840][2015-09-14T13:16:59]i000: BentleyBundle Version 08.21.03.52
    [0C0C:1840][2015-09-14T13:16:59]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\MarkT\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1'
    [0C0C:1840][2015-09-14T13:16:59]i000: Setting string variable 'BundleCurrentPath' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT'
    [0C0C:1840][2015-09-14T13:16:59]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
    [0C0C:1840][2015-09-14T13:16:59]e000: Using Layout File : C:\Users\MarkT\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1\Setup.lyt
    [0C0C:1840][2015-09-14T13:17:00]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
    [0C0C:1840][2015-09-14T13:17:00]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,Configuration,FileAssociationFeature'
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicCoreStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicLangStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]e000: Failed for Package Id: VisualBasicLang2
    [0C0C:1840][2015-09-14T13:17:00]i000: DotNet451FullStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: BentleyConnectClientStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackageStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_FileAssociationFeatureStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_ConfigurationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:1840][2015-09-14T13:17:00]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualizationContentStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: MetroStationWorkSetsStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: PointTools32Extx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]e000: Failed for Package Id: PowerProductLanguagePack
    [0C0C:1840][2015-09-14T13:17:00]i000: MicroStationDocumentationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIFilterSetUpx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIndexerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnPreviewHandlerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnThumbnailProvierStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: HDRPreviewExtension_x64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: ItgDgnDbImporterStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:00]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Unknown
    [0C0C:1840][2015-09-14T13:17:00]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
    [0C0C:1840][2015-09-14T13:17:00]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
    [0C0C:1840][2015-09-14T13:17:00]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:1840][2015-09-14T13:17:01]i000: Display is set to Passive
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]i000: Register callbak=ProxySettingsPage
    [0C0C:1840][2015-09-14T13:17:01]i000: Display Page=ProxySettingsPage
    [0C0C:1840][2015-09-14T13:17:01]i000: Cannot Display Page=ProxySettingsPage
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
    [0C0C:1840][2015-09-14T13:17:01]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
    [0C0C:05E0][2015-09-14T13:17:01]i100: Detect begin, 18 packages
    [0C0C:05E0][2015-09-14T13:17:01]i000: DetectBegin: Installed State of Package DetectedAbsent
    [0C0C:05E0][2015-09-14T13:17:01]i000: Registry key not found. Key = 'SOFTWARE\Bentley\BentleyDesktopClient\Install'
    [0C0C:05E0][2015-09-14T13:17:01]i000: Setting string variable 'NetFramework45Version' to value '379893'
    [0C0C:05E0][2015-09-14T13:17:01]i000: ReferenceId 63645=63645
    [0C0C:05E0][2015-09-14T13:17:01]i000: ReferenceId [VBA_LANGUAGE_PRGID_1033]=63644
    [0C0C:05E0][2015-09-14T13:17:01]i052: Condition '(NetFramework45Version >= 378758 AND VersionNT < v6.3) OR (NetFramework45Version >= 378675 AND VersionNT >= v6.3)' evaluates to true.
    [0C0C:05E0][2015-09-14T13:17:01]i000: ReferenceId 64771=64771
    [0C0C:05E0][2015-09-14T13:17:01]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.0.15' evaluates to false.
    [0C0C:05E0][2015-09-14T13:17:01]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade
    [0C0C:05E0][2015-09-14T13:17:01]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade
    [0C0C:05E0][2015-09-14T13:17:01]i103: Detected related package: {454AD0FD-21D2-4E73-99E9-A40CAC75A636}, scope: PerMachine, version: 1.0.20.0, language: 0 operation: MajorUpgrade
    [0C0C:05E0][2015-09-14T13:17:01]i103: Detected related package: {775616F7-2D4C-4D73-8773-A66C0BCECB38}, scope: PerMachine, version: 1.0.20.0, language: 0 operation: MajorUpgrade
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: VisualBasicCore, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: VisualBasicLang, state: Present, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DotNet451Full, state: Present, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: BentleyConnectClient, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: PowerProductPackage, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent
    [0C0C:05E0][2015-09-14T13:17:01]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent
    [0C0C:05E0][2015-09-14T13:17:01]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: PointTools32Extx86, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: MicroStationDocumentation, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DgnIndexer, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DgnPreviewHandler, state: Present, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DgnThumbnailProvier, state: Present, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DgnODBCDriverx64, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: DgnODBCDriverx86, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: VisualizationContent, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: MetroStationWorkSets, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i101: Detected package: UserAddedPackagesInstaller, state: Absent, cached: None
    [0C0C:05E0][2015-09-14T13:17:01]i000: Setting string variable 'BePlannedAction' to value 'Install'
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_WinTabFeatureAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: PowerProductLanguagePackAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Install
    [0C0C:05E0][2015-09-14T13:17:01]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
    [0C0C:05E0][2015-09-14T13:17:01]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
    [0C0C:05E0][2015-09-14T13:17:01]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
    [0C0C:05E0][2015-09-14T13:17:01]i000: RelatedBundle_Type=None; PlannedAction=Install
    [0C0C:1840][2015-09-14T13:17:01]i000: WixInstallBA::Plan
    [0C0C:1840][2015-09-14T13:17:01]i000: WixInstallBA::SetupModel Plan
    [0C0C:1840][2015-09-14T13:17:01]i000: SetupModel::Before Plan
    [0C0C:16B4][2015-09-14T13:17:01]i000: Before Plan Async
    [0C0C:16B4][2015-09-14T13:17:01]i000: SetupViewModel::Before Plan
    [0C0C:05E0][2015-09-14T13:17:01]i052: Condition '(NOT BuildType_NotSameBuildType) OR Skip_BuildTypeCheck' evaluates to true.
    [0C0C:05E0][2015-09-14T13:17:01]i000: WixInstallBA::SilentPlan
    [0C0C:05E0][2015-09-14T13:17:01]i000: Cannot find Directory C:\ProgramData\Bentley\CONNECT Edition\
    [0C0C:05E0][2015-09-14T13:17:01]i000: AutoCad Civil 3D ObjectEnabler:Searching
    [0C0C:05E0][2015-09-14T13:17:01]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
    [0C0C:05E0][2015-09-14T13:17:01]i199: Detect complete, result: 0x0
    [0C0C:16B4][2015-09-14T13:17:01]i000: IsAnythingToDownload: Demanded by VisualBasicCore
    [0C0C:16B4][2015-09-14T13:17:01]i000: ConnectAndUpdateDownloadSource: Connecting to BentleyServer for download paths
    [0C0C:16B4][2015-09-14T14:23:36]i000: TryConnectingBentleyServer: NetworkException System.TimeoutException
    [0C0C:16B4][2015-09-14T14:23:36]i000: TryConnectingBentleyServer: NetworkException The request channel timed out attempting to send after 00:01:00. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
    [0C0C:16B4][2015-09-14T14:23:36]i000: IsAnythingToDownload: Demanded by VisualBasicCore
    [0C0C:16B4][2015-09-14T14:23:36]i000: DisplayMessage (Installation failed with error code 0x0.)
    [0C0C:16B4][2015-09-14T14:23:36]i000: DisplayMessage (Check internet connection and restart the setup)
    [0C0C:16B4][2015-09-14T14:23:36]i000: WixInstallBA::Before Plan Complete
    Operating system information.txt
    System Information
    Time of this report: 9/14/2015, 14:40:03
           Machine name: MARKT-HP
       Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150722-0600)
               Language: English (Regional Setting: English)
    System Manufacturer: Hewlett-Packard
           System Model: HP Z820 Workstation
                   BIOS: Default System BIOS
              Processor: Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz (12 CPUs), ~2.1GHz
                 Memory: 16384MB RAM
    Available OS Memory: 16308MB RAM
              Page File: 4321MB used, 28292MB available
            Windows Dir: C:\windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7601.17514 64bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
          Display Tab 2: No problems found.
            Sound Tab 1: No problems found.
              Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
              Card name: NVIDIA Quadro K4000
           Manufacturer: NVIDIA
              Chip type: Quadro K4000
               DAC type: Integrated RAMDAC
             Device Key: Enum\PCI\VEN_10DE&DEV_11FA&SUBSYS_079C103C&REV_A1
         Display Memory: 2721 MB
       Dedicated Memory: 3015 MB
          Shared Memory: 3801 MB
           Current Mode: 1920 x 1080 (32 bit) (60Hz)
           Monitor Name: Generic PnP Monitor
          Monitor Model: Philips 272C4
             Monitor Id: PHLC0C9
            Native Mode: 2560 x 1440(p) (59.951Hz)
            Output Type: DVI
            Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver File Version: 9.18.0013.1144 (English)
         Driver Version: 9.18.13.1144
            DDI Version: 11
           Driver Model: WDDM 1.1
      Driver Attributes: Final Retail
       Driver Date/Size: 4/23/2013 20:38:12, 18061328 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp:
      Device Identifier: {D7B71E3E-52BA-11CF-F477-91271CC2C435}
              Vendor ID: 0x10DE
              Device ID: 0x11FA
              SubSys ID: 0x079C103C
            Revision ID: 0x00A1
     Driver Strong Name: oem139.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section027:9.18.13.1144:pci\ven_10de&dev_11fa&subsys_079c103c
         Rank Of Driver: 00E00001
            Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
       Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
           D3D9 Overlay: Supported
                DXVA-HD: Supported
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Enabled
             Monitor Id: PHLC0C9
            Output Type: DVI
            DDI Version: 11
            WHQL Logo'd: Yes
        WHQL Date Stamp:
              Vendor ID: 0x10DE
              Device ID: 0x11FA
            Revision ID: 0x00A1
                DXVA-HD: Supported
             D3D Status: Enabled
             AGP Status: Enabled
    Sound Devices
                Description: Speakers (Realtek High Definition Audio)
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0262&SUBSYS_103C158B&REV_1002
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                Driver Name: RTKVHD64.sys
             Driver Version: 6.00.0001.7161 (English)
                WHQL Logo'd: Yes
              Date and Size: 1/22/2014 04:25:26, 3849304 bytes
                Other Files:
            Driver Provider: Realtek Semiconductor Corp.
             HW Accel Level: Basic
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver: n/a
          Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
          Device Name: HP Elite USB Keyboard
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x03F0, 0x034A
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x1D2D
    | Matching Device ID: usb\root_hub20
    | Service: usbhub
    | Driver: usbhub.sys, 2/17/2014 21:13:42, 343040 bytes
    | Driver: usbd.sys, 2/17/2014 21:13:42, 7808 bytes
    +-+ Generic USB Hub
    | | Vendor/Product ID: 0x8087, 0x0024
    | | Matching Device ID: usb\class_09
    | | Service: usbhub
    Gameport Devices
    PS/2 Devices
    + Standard PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
    | Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
    + HID Keyboard Device
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    | Driver: kbdhid.sys, 11/21/2010 04:23:47, 33280 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    + Microsoft PS/2 Mouse
    | Matching Device ID: *pnp0f03
    | Service: i8042prt
    | Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
    + HID-compliant mouse
    | Vendor/Product ID: 0x03F0, 0x154A
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    | Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 11/21/2010 04:23:47, 63360 bytes
    | Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
    Disk & DVD/CD-ROM Drives
          Drive: C:
     Free Space: 826.1 GB
    Total Space: 941.6 GB
    File System: NTFS
          Model: ATA WDC WD10EZEX-60M SCSI Disk Device
          Drive: D:
     Free Space: 1.6 GB
    Total Space: 11.2 GB
    File System: NTFS
          Drive: E:
          Model: hp CDDVDW SH-216DB SCSI CdRom Device
         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 147456 bytes
    System Devices
         Name: Intel(R) Management Engine Interface
    Device ID: PCI\VEN_8086&DEV_1D3A&SUBSYS_158B103C&REV_05\3&11583659&0&B0
       Driver: n/a
         Name: Intel(R) 82579LM Gigabit Network Connection
    Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_158B103C&REV_05\3&11583659&0&C8
       Driver: C:\windows\system32\DRIVERS\e1c62x64.sys, 12.06.0045.0000 (English), 2/21/2013 07:14:03, 495888 bytes
       Driver: C:\windows\system32\e1c62x64.din, 1/6/2012 23:02:08, 3114 bytes
       Driver: C:\windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/26/2009 20:05:44, 36472 bytes
       Driver: C:\windows\system32\NicInstC.dll, 9.10.0087.0000 (English), 11/14/2012 13:07:39, 101224 bytes
       Driver: C:\windows\system32\e1cmsg.dll, 10.00.0147.0000 (English), 12/6/2012 12:21:52, 73032 bytes
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 1a - 0E02
    Device ID: PCI\VEN_8086&DEV_0E02&SUBSYS_158B103C&REV_04\3&11583659&0&08
       Driver: C:\windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 184704 bytes
         Name: LSI Adapter, SAS2 2308 Mustang -StorPort
    Device ID: PCI\VEN_1000&DEV_0086&SUBSYS_158B103C&REV_05\4&263058AB&0&0008
       Driver: C:\windows\system32\DRIVERS\lsi_sas2.sys, 2.00.0058.0001 (English), 7/3/2012 21:00:14, 110416 bytes
       Driver: C:\windows\system32\wdcfg.exe, 7/3/2012 21:00:16, 136016 bytes
       Driver: C:\ProgramData\LSI\Wdcfg\DriverConfigParam.def, 7/3/2012 20:18:38, 31066 bytes
         Name: Intel(R) C600+/C220+ series chipset SATA RAID Controller
    Device ID: PCI\VEN_8086&DEV_2826&SUBSYS_158B103C&REV_05\3&11583659&0&FA
       Driver: C:\windows\system32\DRIVERS\iaStorA.sys, 4.00.0000.1040 (English), 1/29/2014 06:48:14, 580592 bytes
       Driver: C:\windows\system32\DRIVERS\iaStorF.sys, 4.00.0000.1040 (English), 1/29/2014 06:48:14, 28144 bytes
         Name: Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #2 - 1D2D
    Device ID: PCI\VEN_8086&DEV_1D2D&SUBSYS_158B103C&REV_05\3&11583659&0&D0
       Driver: C:\windows\system32\drivers\usbehci.sys, 6.01.7601.18328 (English), 2/17/2014 21:13:42, 53248 bytes
       Driver: C:\windows\system32\drivers\usbport.sys, 6.01.7601.18328 (English), 2/17/2014 21:13:42, 325120 bytes
       Driver: C:\windows\system32\drivers\usbhub.sys, 6.01.7601.18328 (English), 2/17/2014 21:13:42, 343040 bytes
         Name: Intel(R) 82574L Gigabit Network Connection
    Device ID: PCI\VEN_8086&DEV_10D3&SUBSYS_158B103C&REV_00\4&27885300&0&00E0
       Driver: C:\windows\system32\DRIVERS\e1q62x64.sys, 12.07.0027.0000 (English), 3/27/2013 20:10:35, 495376 bytes
       Driver: C:\windows\system32\e1q62x64.din, 1/12/2013 02:17:13, 3097 bytes
       Driver: C:\windows\system32\NicInstQ.dll, 9.11.0000.0000 (English), 3/2/2013 13:45:08, 101152 bytes
       Driver: C:\windows\system32\e1qmsg.dll, 10.00.0152.0000 (English), 3/7/2013 11:50:15, 73480 bytes
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 DMI2 - 0E00
    Device ID: PCI\VEN_8086&DEV_0E00&SUBSYS_158B103C&REV_04\3&11583659&0&00
       Driver: n/a
         Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_158B103C&REV_A5\3&11583659&0&F0
         Name: Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26
    Device ID: PCI\VEN_8086&DEV_1D26&SUBSYS_158B103C&REV_05\3&11583659&0&E8
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 IOAPIC - 0E2C
    Device ID: PCI\VEN_8086&DEV_0E2C&SUBSYS_0E2C8086&REV_04\3&11583659&0&2C
       Driver: n/a
         Name: LSI 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_158B103C&REV_70\4&39251CCA&0&08F0
       Driver: C:\windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17662 (English), 9/30/2014 11:00:52, 229888 bytes
         Name: Intel(R) C600 Series Chipset SAS RAID (SATA mode)
    Device ID: PCI\VEN_8086&DEV_1D6B&SUBSYS_158B103C&REV_05\4&C64B517&0&0088
       Driver: C:\windows\system32\DRIVERS\iaStorS.sys, 4.00.0000.1040 (English), 1/29/2014 06:48:14, 658928 bytes
         Name: Intel(R) C600/X79 series chipset SMBus Host Controller - 1D22
    Device ID: PCI\VEN_8086&DEV_1D22&SUBSYS_158B103C&REV_05\3&11583659&0&FB
       Driver: n/a
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 IIO RAS - 0E2A
    Device ID: PCI\VEN_8086&DEV_0E2A&SUBSYS_158B103C&REV_04\3&11583659&0&2A
       Driver: n/a
         Name: NVIDIA Quadro K4000
    Device ID: PCI\VEN_10DE&DEV_11FA&SUBSYS_079C103C&REV_A1\4&45A1E28&0&0018
       Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0013.1144 (English), 4/23/2013 20:37:56, 233760 bytes
       Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 4/23/2013 20:38:13, 1106024 bytes
       Driver: C:\windows\System32\DriverStore\FileRepository\nvwu.inf_amd64_neutral_071da6a518957ee2\NvCplSetupInt.exe, 1.00.0001.0000 (English), 4/23/2013 20:38:46, 73373104 bytes
       Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:04, 286536 bytes
       Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 4/23/2013 20:38:12, 4096 bytes
       Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:13, 193336 bytes
       Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:04, 327248 bytes
       Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 4/23/2013 20:38:12, 4096 bytes
       Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:13, 228880 bytes
       Driver: C:\Program Files\NVIDIA Corporation\license.txt, 4/23/2013 20:37:54, 21898 bytes
       Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.00.4647.21994 (English), 4/23/2013 20:37:55, 1562400 bytes
       Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 4/23/2013 20:38:12, 223008 bytes
       Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 4/23/2013 20:38:15, 40574 bytes
       Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.1144 (English), 4/23/2013 20:38:15, 241440 bytes
       Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:17, 428320 bytes
       Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 4/23/2013 20:38:34, 53024 bytes
       Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 4/23/2013 20:38:34, 61216 bytes
       Driver: C:\windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.1144 (English), 4/23/2013 20:38:17, 11077920 bytes
       Driver: C:\windows\system32\nvEncodeAPI64.dll, 6.14.0013.1144 (English), 4/23/2013 20:38:15, 420128 bytes
       Driver: C:\windows\system32\nvapi64.dll, 9.18.0013.1144 (English), 4/23/2013 20:37:56, 2833232 bytes
       Driver: C:\windows\system32\nvcompiler.dll, 8.17.0013.1144 (English), 4/23/2013 20:37:58, 25256224 bytes
       Driver: C:\windows\system32\nvcuda.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:02, 9393344 bytes
       Driver: C:\windows\system32\nvcuvenc.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:03, 2347296 bytes
       Driver: C:\windows\system32\nvcuvid.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:03, 2906912 bytes
       Driver: C:\windows\system32\nvd3dumx.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:12, 18061328 bytes
       Driver: C:\windows\system32\nvinfo.pb, 4/23/2013 20:38:15, 17266 bytes
       Driver: C:\windows\system32\nvinitx.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:16, 245872 bytes
       Driver: C:\windows\system32\nvoglv64.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:26, 26938656 bytes
       Driver: C:\windows\system32\nvopencl.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:27, 7567136 bytes
       Driver: C:\windows\system32\nvumdshimx.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:29, 1107440 bytes
       Driver: C:\windows\system32\nvwgf2umx.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:34, 15054288 bytes
       Driver: C:\windows\SysWow64\nvEncodeAPI.dll, 6.14.0013.1144 (English), 4/23/2013 20:38:15, 364832 bytes
       Driver: C:\windows\SysWow64\nvapi.dll, 9.18.0013.1144 (English), 4/23/2013 20:37:55, 2512336 bytes
       Driver: C:\windows\SysWow64\nvcompiler.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:01, 17560352 bytes
       Driver: C:\windows\SysWow64\nvcuda.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:02, 7935352 bytes
       Driver: C:\windows\SysWow64\nvcuvenc.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:03, 1988384 bytes
       Driver: C:\windows\SysWow64\nvcuvid.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:04, 2722592 bytes
       Driver: C:\windows\SysWow64\nvd3dum.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:08, 15135104 bytes
       Driver: C:\windows\SysWow64\nvinit.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:16, 201576 bytes
       Driver: C:\windows\SysWow64\nvoglv32.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:21, 20458784 bytes
       Driver: C:\windows\SysWow64\nvopencl.dll, 8.17.0013.1144 (English), 4/23/2013 20:38:29, 6264680 bytes
       Driver: C:\windows\SysWow64\nvumdshim.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:29, 962216 bytes
       Driver: C:\windows\SysWow64\nvwgf2um.dll, 9.18.0013.1144 (English), 4/23/2013 20:38:32, 12642504 bytes
       Driver: C:\windows\system32\nvdispco6431144.dll, 2.00.0029.0004 (English), 4/23/2013 20:38:12, 1814304 bytes
       Driver: C:\windows\system32\nvdispgenco6431144.dll, 2.00.0016.0002 (English), 4/23/2013 20:38:13, 1510176 bytes
         Name: Intel(R) C600/X79 series chipset LPC Controller - 1D41
    Device ID: PCI\VEN_8086&DEV_1D41&SUBSYS_158B103C&REV_05\3&11583659&0&F8
       Driver: C:\windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
         Name: High Definition Audio Controller
    Device ID: PCI\VEN_8086&DEV_1D20&SUBSYS_158B103C&REV_05\3&11583659&0&D8
       Driver: C:\windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 122368 bytes
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 VTd/Memory Map/Misc - 0E28
    Device ID: PCI\VEN_8086&DEV_0E28&SUBSYS_158B103C&REV_04\3&11583659&0&28
       Driver: n/a
         Name: Intel(R) C600/X79 series chipset PCI Express Virtual Root Port - 1D3E
    Device ID: PCI\VEN_8086&DEV_1D3E&SUBSYS_158B103C&REV_05\3&11583659&0&88
         Name: Intel(R) C600/X79 series chipset PCI Express Root Port 5 - 1D18
    Device ID: PCI\VEN_8086&DEV_1D18&SUBSYS_158B103C&REV_B5\3&11583659&0&E5
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 3a - 0E08
    Device ID: PCI\VEN_8086&DEV_0E08&SUBSYS_158B103C&REV_04\3&11583659&0&18
    Device ID: PCI\VEN_10DE&DEV_0E0B&SUBSYS_079C103C&REV_A1\4&45A1E28&0&0118
         Name: Intel(R) Active Management Technology - SOL (COM3)
    Device ID: PCI\VEN_8086&DEV_1D3D&SUBSYS_158B103C&REV_05\3&11583659&0&B3
       Driver: n/a
         Name: Intel(R) C600/X79 series chipset PCI Express Root Port 3 - 1D14
    Device ID: PCI\VEN_8086&DEV_1D14&SUBSYS_158B103C&REV_B5\3&11583659&0&E6
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 2a - 0E04
    Device ID: PCI\VEN_8086&DEV_0E04&SUBSYS_158B103C&REV_04\3&11583659&0&10
         Name: Standard Dual Channel PCI IDE Controller
    Device ID: PCI\VEN_8086&DEV_1D3C&SUBSYS_158B103C&REV_05\3&11583659&0&B2
       Driver: C:\windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 02:45:45, 12352 bytes
       Driver: C:\windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 02:45:46, 48720 bytes
       Driver: C:\windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 02:52:21, 24128 bytes
       Driver: C:\windows\system32\DRIVERS\ataport.sys, 6.01.7601.18231 (English), 12/4/2013 02:15:07, 155584 bytes
         Name: Intel(R) C600/X79 series chipset PCI Express Root Port 2 - 1D12
    Device ID: PCI\VEN_8086&DEV_1D12&SUBSYS_158B103C&REV_B5\3&11583659&0&E0
         Name: Intel(R) Xeon(R)�E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 1b - 0E03
    Device ID: PCI\VEN_8086&DEV_0E03&SUBSYS_158B103C&REV_04\3&11583659&0&09
         Name: Texas Instruments XHCI Controller
    Device ID: PCI\VEN_104C&DEV_8241&SUBSYS_158B103C&REV_02\4&2FA50F60&0&00E6
       Driver: C:\windows\system32\DRIVERS\tixhci.sys, 1.16.0003.0000 (English), 7/31/2013 01:16:10, 412936 bytes
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.18741
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.18741
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.18741
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.18741
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.18741
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.18741
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.18741
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Line 21 Decoder,0x00600000,1,1,,
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.18741
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.18741
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
    File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.18741
    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
    Overlay Mixer2,0x00200000,1,1,,
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18501
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18501
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
    Overlay Mixer,0x00200000,0,0,,
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.18741
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.18741
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.18741
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.18741
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.18741
    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.18741
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.18741
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.18741
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.18741
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.18741
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.18741
    WDM Streaming Capture Devices:
    Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    WDM Streaming Rendering Devices:
    Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.18741
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.18741
    DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18741
    EVR Power Information
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
      Quality Flags: 2576
        Enabled:
        Force throttling
        Allow half deinterlace
        Allow scaling
        Decode Power Usage: 100
      Balanced Flags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force half deinterlace
        Force scaling
        Decode Power Usage: 50
      PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        Decode Power Usage: 0
    Vishal Sharma said:
    Is the machine behind proxy? If yes, are those settings used for Internet Explorer?
    Please try with the command
    Setup.exe /passive
    This will force initiate the installation without a wait.
    I do not think the machine is behind the proxy, it is connected to the internet via the network switch.
    I have tried installing using the command mentioned above and it does skip to the installation dialog without asking to configure the features and it still fails.
    I have attached the log file and operating system for information.
  • I have created a Deployment image on the other machine that has Mircostation CONNECT editon on it, it went fine until there is an error message saying "Failed to copy payload for Mircosoft Visual Basic for Application 7.1 (x64)"
    I have attached the screenshot and log file for your information. I can see that installation created a file called "Setup_MircoStationx64_10.00.00.025.exe" - I have tried installing using that file and after waiting for a while an error message came up "Failed to copy payload for Mircosoft Visual Basic for Application 7.1 (x64)"
    When I installed using the file that was created using Deployment Image and it was first time to see "Creating System Restore Point" on the installation dialog, it never appear before.
    MicroStation_CONNECT_Edition_20150915093305.log
    [1B0C:1124][2015-09-15T09:33:04]i001: Burn v3.8.1128.0, Windows v6.1 (Build 7601: Service Pack 1), path: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe, cmdline: '/layout'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]MicroStation\ActivationWizard.exe'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeInstallFolderSuffix' to value ' 10.00.00.025'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\MicroStation CONNECT Edition\'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;OrganizationDirectory;WorkSpacesDirectory;WorkSpacesLabel'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;OrganizationDirectory;WorkSpacesDirectory'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{DB956E9F-5699-40DE-BA52-0985F8B2505A}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeBundleCulture' to value 'en'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeBuildType' to value 'Release'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeBundleShortName' to value 'MicroStation'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_MicroStation_en.zip'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{B5DCA1F0-25C2-467A-9FAB-0CA4A25F3ABA}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{EBF4A592-A779-4CC4-95D3-380537144BF3}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_MicroStationDocumentation' to value '{721EB971-B10C-36FA-92D7-604EFA706ACF}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_DgnPreviewHandler' to value '{264B522D-1B7F-4AAF-A32B-55A6BF5679F2}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx64' to value '{BBD53DF6-15BC-3A1C-9E57-AC7291BA12D2}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx86' to value '{712D2EBD-E590-321F-9754-2C533C7C5508}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AAB6451D-BE58-4ABD-BFB0-797C65AFC30B}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_VisualizationContent' to value '{CA467A36-38EC-3C3D-ACEE-BE27EAF062B7}'
    [1B0C:1124][2015-09-15T09:33:04]i000: Initializing string variable 'BeVarProductCode_MetroStationWorkSets' to value '{6D8E2404-9C2A-3661-BB8C-A3B18C199AD8}'
    [1B0C:1124][2015-09-15T09:33:05]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Ken\AppData\Local\Temp\MicroStation_CONNECT_Edition_20150915093305.log'
    [1B0C:1124][2015-09-15T09:33:05]i000: Setting string variable 'WixBundleOriginalSource' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe'
    [1B0C:1124][2015-09-15T09:33:05]i052: Condition 'VersionNT64  > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
    [1B0C:1124][2015-09-15T09:33:05]i000: Loading managed bootstrapper application.
    [1B0C:1124][2015-09-15T09:33:24]i000: Creating BA thread to run asynchronously.
    [1B0C:066C][2015-09-15T09:33:25]i000: BentleyBundle Version 08.21.03.52
    [1B0C:066C][2015-09-15T09:33:25]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Ken\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1'
    [1B0C:066C][2015-09-15T09:33:25]i000: Setting string variable 'BundleCurrentPath' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT'
    [1B0C:066C][2015-09-15T09:33:25]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
    [1B0C:066C][2015-09-15T09:33:25]e000: Using Layout File : C:\Users\Ken\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\.ba1\Setup.lyt
    [1B0C:066C][2015-09-15T09:33:26]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition\'
    [1B0C:066C][2015-09-15T09:33:26]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,Configuration,FileAssociationFeature'
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicCoreStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicLangStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]e000: Failed for Package Id: VisualBasicLang2
    Bootstrapper Application Data is not found for the Feature: VisualBasicLang2
    [1B0C:066C][2015-09-15T09:33:26]i000: DotNet451FullStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: BentleyConnectClientStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackageStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_FileAssociationFeatureStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
    Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_ConfigurationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:066C][2015-09-15T09:33:26]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualizationContentStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: MetroStationWorkSetsStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: PointTools32Extx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]e000: Failed for Package Id: PowerProductLanguagePack
    Bootstrapper Application Data is not found for the Feature: PowerProductLanguagePack
    [1B0C:066C][2015-09-15T09:33:26]i000: MicroStationDocumentationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIFilterSetUpx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIndexerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnPreviewHandlerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnThumbnailProvierStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: HDRPreviewExtension_x64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: ItgDgnDbImporterStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:26]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Unknown
    [1B0C:066C][2015-09-15T09:33:26]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
    [1B0C:066C][2015-09-15T09:33:26]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
    [1B0C:066C][2015-09-15T09:33:26]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:066C][2015-09-15T09:33:29]i000: Display is set to Full
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]i000: Register callbak=ProxySettingsPage
    [1B0C:066C][2015-09-15T09:33:31]i000: Display Page=ProxySettingsPage
    [1B0C:066C][2015-09-15T09:33:31]i000: Cannot Display Page=ProxySettingsPage
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
    [1B0C:066C][2015-09-15T09:33:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
    [1B0C:1124][2015-09-15T09:33:36]i100: Detect begin, 18 packages
    [1B0C:1124][2015-09-15T09:33:36]i000: DisplayMessage (Same or lower version is found on the machine)
    [1B0C:1124][2015-09-15T09:33:36]i000: DetectBegin: Installed State of Package DetectedPresent
    [1B0C:1124][2015-09-15T09:33:36]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.00.015'
    [1B0C:1124][2015-09-15T09:33:36]i000: Setting string variable 'NetFramework45Version' to value '378758'
    [1B0C:1124][2015-09-15T09:33:36]i000: ReferenceId 63645=63645
    [1B0C:1124][2015-09-15T09:33:36]i000: ReferenceId [VBA_LANGUAGE_PRGID_1033]=63644
    [1B0C:1124][2015-09-15T09:33:36]i052: Condition '(NetFramework45Version >= 378758 AND VersionNT < v6.3) OR (NetFramework45Version >= 378675 AND VersionNT >= v6.3)' evaluates to true.
    [1B0C:1124][2015-09-15T09:33:36]i000: ReferenceId 64771=64771
    [1B0C:1124][2015-09-15T09:33:36]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.0.15' evaluates to true.
    [1B0C:1124][2015-09-15T09:33:36]w120: Detected partially cached package: PowerProductPackage, invalid payload: PowerProductPackage, reason: 0x80070570
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: VisualBasicCore, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: VisualBasicLang, state: Present, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DotNet451Full, state: Present, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: BentleyConnectClient, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: PowerProductPackage, state: Present, cached: Partial
    [1B0C:1124][2015-09-15T09:33:36]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Local
    [1B0C:1124][2015-09-15T09:33:36]i104: Detected package: PowerProductPackage, feature: Configuration, state: Local
    [1B0C:1124][2015-09-15T09:33:36]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Local
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: PointTools32Extx86, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: MicroStationDocumentation, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DgnIndexer, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DgnPreviewHandler, state: Present, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DgnThumbnailProvier, state: Present, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DgnODBCDriverx64, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: DgnODBCDriverx86, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: ItgDgnDbImporter, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: VisualizationContent, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: MetroStationWorkSets, state: Present, cached: Complete
    [1B0C:1124][2015-09-15T09:33:36]i101: Detected package: UserAddedPackagesInstaller, state: Absent, cached: None
    [1B0C:1124][2015-09-15T09:33:36]i000: Setting string variable 'BePlannedAction' to value 'Layout'
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_WinTabFeatureAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: PowerProductLanguagePackAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Layout
    [1B0C:1124][2015-09-15T09:33:36]i000: UserAddedPackagesInstaller RestoreFeatureState: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: UserAddedPackagesInstaller RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [1B0C:1124][2015-09-15T09:33:36]i000: WixInstallBA::SilentPlan
    [1B0C:1124][2015-09-15T09:33:36]i000: Cannot find File C:\ProgramData\Bentley\CONNECT Edition\Configuration\WorkSpaceInstalledSetup.cfg
    [1B0C:1124][2015-09-15T09:33:36]i000: AutoCad Civil 3D ObjectEnabler:Searching
    [1B0C:1124][2015-09-15T09:33:36]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
    [1B0C:1124][2015-09-15T09:33:36]i199: Detect complete, result: 0x0
    [1B0C:066C][2015-09-15T09:44:02]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\Image'
    [1B0C:066C][2015-09-15T09:44:11]i000: Setting string variable 'BeLayoutDisplay' to value 'Full'
    [1B0C:066C][2015-09-15T09:44:14]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair" AND NOT BeSkipFeatureConfigDialog' evaluates to true.
    [1B0C:066C][2015-09-15T09:44:19]i000: WixInstallBA::Plan
    [1B0C:066C][2015-09-15T09:44:19]i000: WixInstallBA::SetupModel Plan
    [1B0C:066C][2015-09-15T09:44:19]i000: SetupModel::Before Plan
    [1B0C:14B4][2015-09-15T09:44:19]i000: Before Plan Async
    [1B0C:14B4][2015-09-15T09:44:19]i000: SetupViewModel::Before Plan
    [1B0C:14B4][2015-09-15T09:44:19]i000: WixInstallBA::Before Plan Complete
    [1B0C:14B4][2015-09-15T09:44:19]i000: WixInstallBA::Engine Plan
    [1B0C:1124][2015-09-15T09:44:19]i200: Plan begin, 18 packages, action: Layout
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: VisualBasicCore, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: VisualBasicLang, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DotNet451Full, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: BentleyConnectClient, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: PowerProductPackage, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: PointTools32Extx86, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: MicroStationDocumentation, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DgnIFilterSetUpx64, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DgnIndexer, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DgnPreviewHandler, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DgnThumbnailProvier, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: HDRPreviewExtension_x64, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DgnODBCDriverx64, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: DgnODBCDriverx86, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: ItgDgnDbImporter, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: VisualizationContent, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: MetroStationWorkSets, state: Present, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i201: Planned package: UserAddedPackagesInstaller, state: Absent, default requested: Cache, ba requested: Cache, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [1B0C:1124][2015-09-15T09:44:19]i000: PlanComplete: Called
    [1B0C:1124][2015-09-15T09:44:19]i000: WixInstallBA::Apply
    [1B0C:1124][2015-09-15T09:44:19]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,Configuration,FileAssociationFeature'
    [1B0C:1124][2015-09-15T09:44:19]i000: WixInstallBA::Engine Apply
    [1B0C:1124][2015-09-15T09:44:19]i299: Plan complete, result: 0x0
    [1B0C:1124][2015-09-15T09:44:19]i300: Apply begin
    [1B0C:1124][2015-09-15T09:44:19]i000: DisplayMessage (Created Deployment image at {0})
    [1B0C:1124][2015-09-15T09:44:20]i000: Installation chain initiated package from
    [1B0C:1124][2015-09-15T09:44:20]i000: Installation chain finished package from
    [1B0C:19E4][2015-09-15T09:44:20]i335: Acquiring bundle payload: , copy from: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\ms10000025en.exe
    [1B0C:19E4][2015-09-15T09:44:35]i000: Layout bundle from: 'C:\Users\Ken\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}' to: 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\Image\Setup_MicroStationx64_10.00.00.025.exe'
    [1B0C:19E4][2015-09-15T09:45:01]w343: Prompt for source of package: VisualBasicCore, payload: VisualBasicCore, path: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\Vba71.msi
    [1B0C:19E4][2015-09-15T09:45:01]i000: ResolveSource: Retries value 1
    [1B0C:19E4][2015-09-15T09:45:01]i000: ConnectAndUpdateDownloadSource: Connecting to BentleyServer for download paths
    [1B0C:19E4][2015-09-15T10:05:24]i000: TryConnectingBentleyServer: NetworkException System.TimeoutException
    [1B0C:19E4][2015-09-15T10:05:24]i000: TryConnectingBentleyServer: NetworkException The request channel timed out attempting to send after 00:01:00. Increase the timeout value passed to the call to Request or increase the SendTimeout value on the Binding. The time allotted to this operation may have been a portion of a longer timeout.
    [1B0C:19E4][2015-09-15T10:05:24]e054: Failed to resolve source for file: T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\Vba71.msi, error: 0x80070002.
    [1B0C:19E4][2015-09-15T10:05:24]e000: Error 0x80070002: Failed while prompting for source (original path 'T:\DRG OFF\CAD\MICROSTATION STUFF\MICROSTATION DOWNLOADS\MICROSTATION CONNECT\Vba71.msi').
    [1B0C:19E4][2015-09-15T10:05:24]e313: Failed to acquire payload: VisualBasicCore to working path: C:\Users\Ken\AppData\Local\Temp\{c081fbf9-3cd1-4111-84f5-4bacd6e65f19}\VisualBasicCore, error: 0x80070002.
    [1B0C:19E4][2015-09-15T10:05:24]e000: Caching failed for VisualBasicCore
    [1B0C:19E4][2015-09-15T10:05:24]i000: DisplayMessage (Installation failed with error code 0x0.)
    [1B0C:19E4][2015-09-15T10:05:24]i000: DisplayMessage (Failed to copy payload for Microsoft Visual Basic for Applications 7.1 (x64))
    [1B0C:1124][2015-09-15T10:05:24]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\Ken\AppData\Local\Temp\MicroStation_CONNECT_Edition_20150915093305.zip'
    [1B0C:1124][2015-09-15T10:05:24]i399: Apply complete, result: 0x80070002, restart: None, ba requested restart:  No
