What is the key combination for View Fit All? It's 4,5 in SS3.
Unknown said:T If you'd rather use Position Mapping with the legacy Task Navigation dialog rather than the ribbon, you can define the config var MS_TASKNAVIGATION_CONFIGURATION=1 and switch Task Navigation to one of the legacy presentations in the Preferences dialog.
Just to clarify then, using this config MS_TASKNAVIGATION_CONFIGURATION=1 will remove the ribbon and gives us back the tasks dialog. Is that correct?
It will not remove the ribbon but will give you the option to use the task navigation dialog as before.
When you use MS_TASKNAVIGATION_CONFIGURATION it will give you an additional section in preferences:
If you use the Ribbon option the Task Navigation will remain under the ribbon workflow options:
If you select dialog it will remove it from the pulldown menu and give you the classic task dialog:
As you can see the ribbon will still be present, note that in the above image I simply minimized the ribbon.
In the above situation if you are using position mapping the task dialog will take priority unless you use the F2 or F3 to activate the assigned hotkeys in the ribbon.
