What is the key combination for View Fit All? It's 4,5 in SS3.
stuartw said:Perfect. Just what I need. Thank you. BTW I've set this config in my WorkSpaceSetup.cfg file. Is that correct.
Though setting any configuration variable in any cfg file that is read will work it is recommended that you do not make changes to this file. This type of change should be stored in the Organization/WorkSpace/WorkSet/Role levels.
Unknown said: stuartw Perfect. Just what I need. Thank you. BTW I've set this config in my WorkSpaceSetup.cfg file. Is that correct. Though setting any configuration variable in any cfg file that is read will work it is recommended that you do not make changes to this file. This type of change should be stored in the Organization/WorkSpace/WorkSet/Role levels.
I'm sure that you have previously said as part of the EAP forum that adding configs to this file was OK.
Where are the Organization/WorkSpace/WorkSet/Role levels.in the standard install?
If its not broke don't try and fix it.
Unknown said:it is recommended that you do not make changes to this file.
Seriously? Whats the point of having it under ProgramData rather than Program Files..../config it its not meant to be modified?
