What is the key combination for View Fit All? It's 4,5 in SS3.
Please read the thread, my response was in regards to the Variable that David T. recommended setting.
Unknown said:<<SNIP>>When you use MS_TASKNAVIGATION_CONFIGURATION it will give you an additional section in preferences:<<SNIP>>
stuartw said:<<SNIP>>BTW I've set this config in my WorkSpaceSetup.cfg file. Is that correct.
Unknown said:<<SNIP>>Though setting any configuration variable in any cfg file that is read will work it is recommended that you do not make changes to this file. This type of change should be stored in the Organization/WorkSpace/WorkSet/Role levels.
stuartw said:I'm sure that you have previously said as part of the EAP forum that adding configs to this file was OK.?
Where are the Organization/WorkSpace/WorkSet/Role levels.in the standard install?
Unknown said:If its not broke don't try and fix it. John Frampton it is recommended that you do not make changes to this file. Seriously? Whats the point of having it under ProgramData rather than Program Files..../config it its not meant to be modified?
I am not sure what the point of your post is? If what isn't broke? Please read the file with regards to what type of changes should be made in that file. The file is there and it can be edited by the end use, though with the recent changes made to the Installer there is no reason for the user to edit this file manually. The file is not to hold random variables that are mentioned and I was responding to.
Unknown said:Did John not mean "Organization OR WorkSpace OR WorkSet OR Role levels"? I've currently got mine set at the Organization level
Unknown said:Surely if you follow what it says, you should be good to go? Extract from WorkSpaceSetup below:
You are correct that is the intent of the fie. With the changes we made to the installer from EAP to CR there is no reason for the end user to manually end this file. There is especially no reason to store a random variable that does not pertain to the intent of the file to be stored in it.
