In Word Processor dialog there is underlined text.
Can I get STRIKETHROUGH also?
Fantastic!!! Thank you.
MaryB
Thanks Todd.
I wonder. As far as I know the Text Editor is based on microsoft tech(?) Every other program managing text that I used has this setting.
(but then there are other things that I quarrel with here: like color settings for fonts (you were able to set them on the fly as far as I remember in earlier versions) or that you cannot set text width other than via the text style dialog,...)
JMs VBA is brilliant- but as he said it is again another workaround for something that should be a no brainer
JM said:This is a very roundabout way to achieve a simple result.
very clever Jim, personally for not to true scale dimensions I would built a custom terminator to have a zig zag ... but as I only do one or two of these dims I just drop the dimension and make a manual zig zag with insert vertex tool ... I also have a company vba that draws parallel break lines on top of elements.. but you have to drop dims first other elements its fine but the OP did ask for strike thru so well done..
Lorys
