I've set up Task Navigation using the same DGNLIB that we use for SS3. In CONNECT a number of the icons are missing. How do I get these back?
This was discussed as part of the EAP and I thought resolved.
Just to expand on this. The associated toolbox (opened from "Open XYZ Test as Tool box) is missing the icon and the tools don't actually work!!
If I get the toolbox from the list of Tool Boxes (Ctrl + T) then it opens with all icons and the tool works.
Why doesn't this work from the Tasks dialog?
René R. van den BrinkTechnical SupportBentley Systems Incorporated
Unknown said:Hello Stuart, Could you share your GUI dgnlib's with us? Are you perhaps (re)using, or pointing to, old mdl's from your dgnlib's?
DGNLIB attached as requested.
There are some old MDL's but I know they don't work but there are some default tools that should have icons and work but don't.
ws-gui.dgnlib
