Connect Constraints - 3D concentric
Constraining 2 cylinders to be concentric prevents applying a constrain for distance apart.
I want the axis constrained but need to apply variable to distance apart.  Is this possible?
  • This should be possible assuming I am interpreting your query correctly. please see attached video.
    If this does not help may be you could explain further and/or post a sample file for others to review.
Reply
