ALT + LEFT MOUSE NOT WORKING FOR MATCH ATTRIBUTES
I had possibility to see Microstation Connect for few hours
what i see is that  match not working like in older versions
  • It seems to be working ok on my machine. You are not seeing the attributes change? What are you trying to match them to?
  • This is also working in my instance, if you go to File > Settings > User > Button Assignments is the Alt+Data set the same as you have it in your older version ?
    By default the action is set to 'match attributes fromcursor'
    If still an issue may be you could confirm the version number you was using, and describe further what is different in behavior.
    FYI it works even better if you change the word "attributes" to ELEMENT then it works with matching text attributes too...as well as all the other attributes level, colour etc
    Lorys
    click link to PM me
  • Maybe it was something with mouse, if i have possibility will try, thank you all
  • I have seen this before with logitec mouse not having windows drivers installed and using generic windows driver .. also effected extra  side buttons being not configurable
    what  mouse do you have ?
    can you access the buttons config for the mouse can you save the BTN.mnu locally ?
    IT sometimes stop this file being over written.../ updated...
    Lorys
    click link to PM me
