Are all components of a parametric cell suppose to go on the same level? I have some geometry on default and some on a designated level. It appears everything is placed on the active level.
Kind Regards
Boris Tetleroyd
i think that it doesnt work. or at least does not work how I would have hoped it to.
the attached image illustrates what i am looking for.
in this case i have set up a parametric stair tread which has a concrete tread, a screed and a tile finish. they all need to have different properties. not just levels but also cut patterns, and materials (in order to get the tile geometric pattern).
so if it is the case that i cannot do this, then parametric cells will not be of much use, as i will need to create each piece of the assembly as a separate cell (and i could do that with basic geometry)
p
