I want to use the "measure distance along element" tool in Mircostation. It seems the CONNECT edition stops supporting using this tool along element with reference models in sheet models. I can use this tool in design model without any problems.
To overcome this problem I have to 'merge' the reference model into sheet model to allow me to use the tool which can be time consuming.
It was working fine in older version (Mircostation SelectSeries3)
I can provide a video on what I was talking about if anyone requests it
Thanks in advance
Click on the link below and select the file to view the video as requested.
http://1drv.ms/1MedRKz
Drawing attached as requested.
NW-04A4_04A12.dgn
