It appears only certain display style can be used with View/Ref attachments generated with the section tool. Default is hidden line. I would like Monochrome. It accepts the setting but doesn't display that way.
David, For Views that have multiple display styles it is bested if you change the View to use that display style. For instance a View that is created with section cut graphics has potentially 4 different display styles. Which of them do you want to be monochrome?
The top is how I want it. Done with a good old fashion reference fold. But its not dynamic. Below shows what section gives me. Even if I change the display style
Changing the Presentation via Reference Dialog doesn't work either.
Still not getting it.
