Just found out that the File and Directory history lists are missing from Re-attach Reference dialog. This was really useful and would welcome it back.
Not sure whether the "re-attach reference" dialog would actually be the Attach Reference dialog that you are discussing here. If you look at both dialogs between V8i and CONNECT versions of MicroStation they both have the same File History and Directory History icons listed.
Compared to how this is displayed in MicroStation CONNECT Edition you should see the same icons on the Attach References dialog.
No. I mean the Reattach Reference dialog. See attached. This is from CONNECT.
