WE have a custom sheetsizes.def which is not bring found and used byn CONNECT. I have checked the config opath and it is pointing to the correct file. When I create a new model I should have a list of sheet sizes to pick from for the sheet boundary. I only have one listed with CONNECT. See screenshot. Attached is my sheetsizes.def.
Sheetsizes file attached. Renamed with baksheetsizes - Copy.bak at the end as the forum wouldn't acceptance .def!!
Please make sure your SheetSizes.def file follows the new format. C:/ProgramData/Bentley/Documentation/MicroStation/10.0.0/en/htm/GUID-E5B306F9-9B97-41B6-8F16-B4D42467D15F.html?q=sheetsizes.def Note: this is true with Scales and Units also.
And yes this change is documented in help somewhere.
I've had another go at this and worked out how to change the orientation, which is good, What I can't work out is to change the name. I've added the line:
_[SYSTEM]_ ; 2; 1189; 841; 0.00; 0.00; 0.00; 0.00; 2 ISOA0 portrait
which gives me this from the drop down list:
How do I change the name so that it reads ISO A0 Portrait?
From Sheetsizes.def;
# Name Units Height Width TopMargin LeftMargin BottomMargin RightMargin UnitSystems #Roll paper sizes.
4 Stuart ; 2; 210; 297; 0.00; 0.00; 0.00; 0.00; 2 #4Stuart
From the help;
Where,
HTH.
