WE have a custom sheetsizes.def which is not bring found and used byn CONNECT. I have checked the config opath and it is pointing to the correct file. When I create a new model I should have a list of sheet sizes to pick from for the sheet boundary. I only have one listed with CONNECT. See screenshot. Attached is my sheetsizes.def.
I've had another go at this and worked out how to change the orientation, which is good, What I can't work out is to change the name. I've added the line:
_[SYSTEM]_ ; 2; 1189; 841; 0.00; 0.00; 0.00; 0.00; 2 ISOA0 portrait
which gives me this from the drop down list:
How do I change the name so that it reads ISO A0 Portrait?
From Sheetsizes.def;
# Name Units Height Width TopMargin LeftMargin BottomMargin RightMargin UnitSystems #Roll paper sizes.
4 Stuart ; 2; 210; 297; 0.00; 0.00; 0.00; 0.00; 2 #4Stuart
From the help;
Where,
HTH.
