Hallo,
I used to work with CAD and use _priew or 'p' command to select last chosen objects. Is it possible in Micro?
Sometimes I have to select some objects, cancel it, do sth else and then make the first thing, but I don't want to select objects again. In CAD we can use _priew or p. That makes work more comfortable :) I'd like to do it with micro :)
Unknown said: Hallo, I used to work with CAD and use _priew or 'p' command to select last chosen objects. Is it possible in Micro? Sometimes I have to select some objects, cancel it, do sth else and then make the first thing, but I don't want to select objects again. In CAD we can use _priew or p. That makes work more comfortable :) I'd like to do it with micro :)
Microstation is also CAD , if you ment autocad then say so dont call it cad ( Computer Aided Drafting is cad ) .. its like saying you use Microsoft when you mean MS word.....
any way you can select previous very easily hold the right mouse button down anywhere clear of objects and a second or two later new menu pops it has select previous.. there are other ways but I like this method the best...
Lorys
Try this .....
Key in : Choose Previous
or right click > Select Previous
Really this one helped me a lot to solve my issues.
