"Show configuration" in 10.00.00.25 shows a complete list of the configuration variables.
The variable "_WORKDIR" however is not OK, it points to 08.11
If I start ustation in debug-mode (-debug) there is nothing in the msdebug.txt pointing to 08.11 (also on my PC).
Only in the "Configuration Variable Summary":
_VERSION_10_0 : predefined = (null) <Locked>_WINNT : predefined = (null) <Locked>_WORKDIR : predefined = C:\bentley\0811ss1\MicroStation\ <Locked>
Question: why points _WORKDIR to V8i?
Unknown said:The variable "_WORKDIR" however is not OK
Configuration variable _WORKDIR is not defined in any configuration file. It is defined according to how you start MicroStation.
See this article about Working Directory and Configuration Variables.
Answer Verified By: Kees van Velthoven
