Hello all,
I need help to set multiple dgns to the following symbology before I process a batch place text:
symbology as follows:
LV=0
C0=0
WT=0
I tried this in my txt command file but no change in dgns.
Thanks for any advise
The reference file suggestion by Lorys is a better option if the text, symbology and location is always going to be the same.
In case you need the key-in, here is it.
Will place the text in "Default" levellv=0;co=0;wt=0;lc=0;active font simplex;textstyle active none;active tnj LC;Place Text;XXX;aa=0;th=0.08;tw=0.08;XY=1.46,2.15;choose element
Will place the text in level "test"active level test; co=0;wt=0;lc=0;active font simplex;textstyle active none;active tnj LC;Place Text;XXX;aa=0;th=0.08;tw=0.08;XY=1.46,2.15;choose element
Regards,Leonard Jones
