In V8i the reference properties " " keyin would open up the attachment settings dialog.
Is there a new keyin to access this in Connect?
Any anticipation as to a time frame of the resolution to the above?
Does "Dialog Reference" give the desired result?
Thanks for the response,
"Dialog Reference" opens up the reference dialog to attach/detach etc.. I needed to go 1 step further, open up "Attachment Properties" for a certain reference that is already attached.
