Hi Hi,
I have upgraded to the Connect edition of Microstation as the guinea pig of the office to test it out.
My question :- is it possible to change which letter is used for the keyin when using position mapping with dialog boxes? As an example, the text task is activated when the T button is pushed, how can I get it to be actived with an A button push instead?
Thanks in advance for your help.
Hello,you can do that with these steps:1. Go to File > Setting > User > Preferences.2. In the Preferences dialog select category Position Mapping on the left hand side.3. Modify Tasks & Ribbon field as needed.
I hope this helps!
Regards,Anu
Answer Verified By: MSD Myles
