I want to import some cells with the "connect webrowser" tool. At the moment it doesn´t work. On the same machine in V8i it works well. I checked the settings and the path to my library.
Can everybody help me. Thank you,
Marc
Maria Garcia
Hi Maria,
thanks for your answer.
We don´t want to import cells by 3D-Warehouse, but by our own cell library. I was trying to change the configuration variable MS_CELL and MS_CELLLIST to the path, where is the folder, but there was no success. In the V8i was that not necessary to change the configuration variable there.
If we connect to web browser the internet explorer open and our cells will be open. But it´s not possible to import our cells in the actually file.Here i send you a part of our cell library. With that file, you can create a html file in the html author and with that html file you can open the cells in our cell library.
In the message center was no message after we tried to import our cells.
01_Modell.cel
Hi Marc,
I was testing your file and I created the htm page.I can load the connect browser and paste C:\Users\maria.munoz\Desktop\01_modell.htm to display the two cells (01_Garage and 4-garage-offen) but the only possibilities is to open or save 01_modell.cell for me works the same way as in V8i (I tested with SS3).
As far as I know The HTML Author does not create a web page allowing you to select and insert cells in a design files. For that you need to use the Cell toolbox, attach the file and then insert the cells directly from there.
RegardsMaria
i have seen your movie, but we import the cell to an other way. I have send to that message two movies. The Movie "V8i" shows the import in MicroStation V8i successfull and the movie "Connect Edition" shows no import, it´s unsuccessfull.
In the movies you can see the problem in the connect edition by using connect web browser. Is there a possibility to import the cells with the internet explorer like we do that?
Ciao Marc
