Is the length of dimension text fixed?
I have a dimension and i want to override the dimension with text. So, i activated text edit command and appended the text along with the dimension value(visible as '*' in text editor). Is the length of the dimension text limited? If the input text is about to cross the dimension line, the text is invisible.
Is there any setting that needs to be turned on inorder to make the dimension text visible even if the text wont fit in the dimension width.
Parents Reply Children
  • If the text has so many extra characters that  it still doesnt  look right with Leonards solution then perhaps you need to just replace the * with a space and enter this then leaves the dims empty ie no text ... and add the text later as a separate  note with arrow leader or just plain multiline text above the horizontal dim line so it still fits between the  leaders...some times you just have to make it work to look right on paper and break all the cad rules about association for dims....
    Lorys
    click link to PM me
