MICROSTATION-TURN-OFF LEVEL
I am using Microstation V8i SS2.
I am having to turn-off levels in a file that references other files.  My work flow is to identify which reference file contains the level by turning off the reference, then use the element information dialog to tell me which level is the one to turn off, then I use the level display dialog to locate the level and select to turn-off the level.  Is there a more efficient way to turn off a level without having to search for the file, the level, then find the level in level display, to turn it off ?
Parents Reply Children
