I am using Microstation V8i SS2.
I have used the right click command to Turn Level Off by Element. I I wan to undo that action, I do not get an undo option under the edit pull-down. Is there a way to undo that action if I select the incorrect level?
Answer Verified By: CADTech1
While I am clicking view previous , it's not working. show error message as "No previous viewing operation".
software: AECOsim
Halithfini Fino said:While I am clicking view previous
This post is marked as answered, so few people will given it any attention. Your question is (a) new and (b) unrelated to this post. Please post a new question on this Forum.
Don't forget to tell us the version (e.g. v10.x.y.z) of MicroStation you are using.
Halithfini Fino said:i, While I am clicking view previous , it's not working. show error message as "No previous viewing operation". software: AECOsim
i,
it only works in the active session where changes have occurred during the session not if you close or exit and come back
for example try turn off a level in the active view via the right mouse or the level display NOT THE LEVEL MANAGER..
Now you can see that the objects on that level are gone or not visible.. now try the view previous button the anticlockwise one... and your level should return to on or off whatever it was before you changed it... now control F for the save settings to keep the view setting.. before you exit or go to another drawing...
Lorys
