Next few minutes with CONNECT
i see that selection not working as in SS3. In SS3 perspective view when you keep select ( draw select rectangle ) and make zoom, you can still select what you need
In Connect select ( rectangle ) and zoom not keep selection in position you want
Hello Reginald , i try to find what i'm talking about but now i know - Open 3d model - for example in top view add some perspective - choose selection ( old tasks "1" ) - put start of selection in left bottom corner of window or your left part of model - go with selection to right top corner and try to zoom out / in with mouse roll - like you want to go out of screen to select whole model or most of his part > IN OLD SS3 - selection start point is still in place you choose first > IN CONNECT - not
Dear Reginald
here are the screen videos
see that select left corner is still in place in SS3
And here how it works in CONNECT ( sorry for mistake in first seconds )
you can see that if you select and roll mouse - your selection start point not stay in this point
so you can't select something in this mode fast and exactly and zoom / roll for distance objects
Go to the "Window Area" tool and turn off "Move Camera"
Answer Verified By: martinezx
