Is there a way to set the dialog settings voor "place label" by keyins?
This is to choose cell name; dimension style; enable annotation scale; enable to create associations to elements; ....
Thanks for any help,
Luc Dierick
Derval,
As you can see in attached screenshot the right column is empty when I use "set item toolsettings" for the place label tool....
And I have a fault message in the message center.
Do you have another result for the place label tool in Microstation Connect?
