I am using Microstation V8i SS2.
I have a reference file that is displaying on top of another, incorrectly. I have set the sequence order in the reference dialog under settings and set the file I want on top at the very bottom of the reference file list. However, the display is still opposite of what I want, the file that should be on top is on the bottom but only in some places (boring text labels). How do I remedy this type of inconsistant display order issue.
Unknown said:How do I remedy this type of inconsistant display order issue?
One approach, if your DGN models are 2D, is to use element display priority. Display priority is designed to solve exactly the kind of problem you describe.
You can assign a priority to a level or at an individual element. Most likely easiest to do an entire level:
Are your files 3D? If so, then the actual 3D elevation is what governs this. So anything drawn at elevation 0 would be under anything at a higher elevation, regardless of display order or priority.
Unknown said:I did changed the priority in my plot table which worked. Is that the Display Priority you were referring?
Dean got it — lookup display priority in MicroStation help:
(2D models only) Element Priority is a display-only setting that determines the order in which elements are displayed in a view. Essentially, this display priority setting adds a “calculated Z” value for to 2D co-planar elements, similar to the Z value in 3D models. In 3D models, elements closer to the eye are always displayed in front of elements further from the eye so display priority is not necessary.
In a 2D model, you can assign an active element priority, which sets the display priority value for new elements that you place in the model. The elements assigned the highest element priority value are displayed in the front, while the elements assigned the lowest values are displayed at the back.
In 2D models, you can assign Display Priority values to references, levels, and to individual elements. The hierarchy for display priority is Reference > Level > Element. A reference's display priority takes precedence because its value is multiplied by 1,000,000. A level's display priority is next because its value is multiplied by 1,000. An element's display priority is the lowest priority because it isn't multiplied by any amount. Therefore:
Answer Verified By: CADTech1
