Hi All,
I am having issues with both Microstation V8i and PowerDraft V8i. The grid together with all the cells and elements is "skewed" and it doesn't seem to matter what file I open the same issue exists. I have tried installing the same version on another computer and no issue, so it seems it is unique to this PC and hence may be a driver/graphics issue. See attached pictures of the "skewed" working files. My PC which has this issue is:
Windows 7 Ultimate
Motherboard: EP45T-DS3R Gygabite
CPU: Intel Core Quad Q9550 2.83GHz
RAM: 4GB
Graphics: NVIDIA GeForce 9800 GTX+
I have the latest drivers installed (DirectX) and Nvidia but still not fix to the problem.
Does anyone know the issue? Greatly appreciated.
Thank you.
there are plenty of discussion in this and also other forums about similar display issues related to Nvidia cards (e.g. this or this one). There is also wiki article Troubleshooting Graphic Display issues available.
As described in the mentioned discussions, you should try:
With regards,
Jan
