How do I list more than 10no. files in the Open page? Ten is a relatively small number and this page woould be better used with a longer list. Please could you let me know how to do this?
By pinning your most recently used files, you can list more than 10 files int the Work page (I assume your Open page is my Work page).
HTH, YongAn
Hi Stuart,Have you tried to set the 'Show Details' view for pinned documents? Then you can see the full path for the document, file size and last modified info right away. Scroll bar also appears on the right hand side when the amount of pinned documents increases:
Kind regards,
Anu
Unknown said: Have you tried to set the 'Show Details' view for pinned documents? Then you can see the full path for the document, file size and last modified info right away. Scroll bar also appears on the right hand side when the amount of pinned documents increases:
Thanks for your help and yes I do indeed use 'show details'.
