WMS server and Coordinate system
I want to attach a map through the wms server.
However, the coordinate system needed is not shown in the “Select Coordinate System” dialog.
How do I import/attach  the correct one, to use with the selected service. (I need the EPSG 31370 system)
To compare 2 different maps I need to use the same coordinate system
the correct one needed is shown here (these maps are well attached)
how to attach google maps with the EPSG 31370 system if possible
thanks for help
AECOsim ss6
win7pro
RikR
Parents Reply
  • https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/273/Cadastral.xwmshttps://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/273/BelgiumWMS.xwmsApologies for forgetting the XWMS.  They are attached.  And Jan is correct, I am not aware of a WMS source for Google Maps.  For my testing I drew some lines in the DGN that trace part of the canals in Bruges.  One overlaps Google Earth correctly and one is offset.
    Keith Raymond
