Will Powerdraft be compatible if updating Windows 7 to Windows 10?
Paul, MicroStation CONNECT Edition is certified for use on Windows 10 -- this is included in the ReadMe, which is located on communities.bentley.com/.../271101.
The same will hold true for PowerDraft CONNECT Edition when release. PowerDraft V8i Edition will not be certified on Windows 10.
