With the Connect Edition, how do customize the directory structure that is created when I create a new Workset? I can't find any help on this. With V8i, we have several project template structures setup that we select when creating a new project base on the type of job...Primarily, some complex structures for complex projects and simple structures for simple jobs.
Timothy Hickman
Main: 877 627 3772|
Gary Manuel
OBD 2023
Windows 10 Pro
I've only started playing with this, but you may be able to use the _USTN_WORKSETSTANDARDSUBDIRS configuration variable. In the WorkSpaceSetup.cfg these come commented out as default:
#_USTN_WORKSETSTANDARDSUBDIRS = Cell;Data;Seed;Symb;Macros;Sheet Borders;Superelevation;Template Library #_USTN_WORKSETSTANDARDSUBDIRS > Dgnlib;Dgnlib/GUI;Dgnlib/Render;Dgnlib/DrawComp;Dgnlib/Links;Dgnlib/ClashDetection;Dgnlib/Printing #_USTN_WORKSETSTANDARDSUBDIRS > Dgnlib/Civil Cells;Dgnlib/Feature Definitions;Dgnlib/Sheet Seeds;Dgnlib/Graphical Filters
That doesn't solve the problem of files, but it should generate your directory structure.
Files seem to be a bit more...unpredictable. There is the concept of the Workset Template, but I find more posts about how it doesn't seem to work as expected, than how it does. I did a quick search of the Project Administration Forum and didn't find much helpful discussion with easy fixes.
MaryB
Thanks, Mary. I will look into these variables and see if we get something close.
I've been looking into this a lot recently. It's been a frustrating exercise to say the least. I've got a few service tickets open for things that aren't working properly.
There are three basic ways to set up a WorkSet Template.
Method #1 - Using configuration variables
In a configuration file you will need to set the following three variables and also create the corresponding seed .cfg and .dgnws files.
#-------------------------------------------------------------------- # WorkSet #-------------------------------------------------------------------- _USTN_WORKSETTEMPLATE = $(_USTN_ORGANIZATION)seed/WorkSets/$(_USTN_WORKSPACENAME)_WorkSet_Template.cfg _USTN_WORKSETDGNWSTEMPLATE = $(_USTN_ORGANIZATION)seed/WorkSets/$(_USTN_WORKSPACENAME)_WorkSet_Template.dgnws _USTN_WORKSETSTANDARDSUBDIRS = Cell;Data;Seed;Symb;Macros;Dgnlib;Dgnlib\GUI;Dgnlib\Render;Dgnlib\DrawComp;Dgnlib\Links;Dgnlib\ClashDetection;Dgnlib\Printing;Template Library
When creating a new WorkSet the seed files are copied for the new WorkSet .cfg file and dgnws file, and the Standards subfolders are created. It kind of works, but has problems:
Method #2 - Using a complete template WorkSet.
For this method you create a complete custom seed WorkSet template where all of your other regular WorkSets are located. When you create a new WorkSet you select your template WorkSet from the drop-down.
This solves the two main issues with Method #1, but has another big problem. There is no way that I have found to prevent users from accidently picking the template WorkSet as their active WorkSet and adding dgn files and other files to it, thus mucking up your template.
Method #3 - Creating a custom WorkSet creation tool
We've been asked by multiple clients to create a custom tool to create WorkSets for each new project. The reason for this is that they want their WorkSet configuration file to reside in the default WorkSets folder, but the dgn files, .dgnws file, project ORD .itl file, etc. to be stored under their company standard Projects folder on a separate network drive in many cases. To complicate matters the project folder names do not directly correspond to the WorkSet name, so the WorkSet configuration file has to have variable modifications when the WorkSet is created to reference the correct folder. One company even wants to pass the job of creating new projects/WorkSets to an Office Manager type person who doesn't need any Bentley products installed.It may sound complicated, but it's not a difficult application to develop.
This method is a non-starter at present as you cannot move/rename the .dgnws file without corrupting it.
Rod WingSenior Systems Analyst
I, too, am interested in setting up a WorkSet Template. I would like to include a few Custom Properties for use with Title Blocks, etc. I would also like to create a standard set of folders. I would also like to specify the location of the main project (WorkSet) folder.
I set up a WorkSet with the custom properties that I want, and I manually added a few other folders (besides dgn, out, and Standards and it's subfolders).
I notice that when I try to use this WorkSet as a template for a new workSet it doesn't allow me to select the folder for the new WorkSet.
At the very least I would like to standardize the Custom Properties across any new WorkSets. So far I have just created Worksets with no template. I then manually added in the other necessary folders.
Can I do any or all of this with a WorkSet template?1. Define Custom Properties2. Create a folder structure that includes folders outside of the Standards folder3. Choose the location of the WorkSet folder?
Thank you.
Using Method #2 as I described above you can accomplish items 1 & 2.
The WorkSet template must reside in the folder where your new WorkSets will be created. You can change the location by modifying the variable _USTN_WORKSETSROOT
Thank you. I will look into this. But it raises a bigger-picture question:
We use the same exact standards for all of our projects. We are a local government engineering office producing plans for our own use. We don't have different client workspaces, etc. The only benefit of using WorkSets is the use of a dgnws file. Is there a reason I can't just use the same WorkSet for all projects? I have only created a dozen or so WorkSets so far, but as I create more and more over the next few years the drop-down list of WorkSets is going to get annoyingly long - all using the same standards other than maybe a local template library.
In SS2 all users used the same Project and Interface for all projects, but and our own User..
That's a common concern for a lot of companies. We have numerous clients that are just using the one WorkSet for everything model.
There are three drawbacks to going with a single WorkSet
Josh M said: I would like to include a few Custom Properties for use with Title Blocks, etc.
One more thing that I forgot...
If you are using OpenRoads Designer, many companies like to have a project-specific template library (.itl file). You really can't set that up if you're using one WorkSet for everything.
Thanks, Rod.
Since I would like to use custom properties and project-specific template libraries I think I will continue to use separate worksets for now.
I also would like to use a template but be able to specify where to create the folder structure. If I don't use a template I can specify where to create the folders (anywhere on the server). When I use a template the folder location options are greyed out.. Workset 3670 was created in a completely different folder on a network drive.
In my WorkSet template I set up a folder structure similar to the image on the left. I would like to able to use this folder setup when creating a new workset from this template. Up until now I just added the other folders manually after creating the Workset. Is it possible to do what I am asking? Like I said, when using a WorkSet Template the root folder option is greyed out.
