For some reason when I go to place a cell my Active angle is getting set to 45 and my Active scale to 100 and its not file specific.
File Settings
Tools settings displays properly. However cell dynamics show differently
I then toggle the increase angle arrow. This should result in 90 but it goes to 135
I then clicked on the scale ratio lock and the scales switch from 1 to 100.
It does not appear to be library dependent. It may be file dependent as I'm seeing this in one specific project.
Here as a cleaned file which exhibits the issue.
BADAngle.dgn
If you look at the File > Properties you will see that the active scale is set to 100 and the Active angle to 45 degrees.
The following keyins can be used to reset these and once done they Place Cell tool will be reset.
aa=0
as=1
Don't forget to do a Save Settings, you may also want to review the seed file used to create this file and adjust if required.
Carl Myhill
Technical Support Engineer
Bentley Systems
