Connect - Active Angle and Scale keeps resetting on place cell
For some reason when I go to place a cell my Active angle is getting set to 45 and my Active scale to 100 and its not file specific.
File Settings
Tools settings displays properly.  However cell dynamics show differently
I then toggle the increase angle arrow.  This should result in 90 but it goes to 135
I then clicked on the scale ratio lock and the scales switch from 1 to 100.
  • BADAngle.zipThis appeared to have worked for me, I did a file Save Settings and File Save. I attach the file for reference.
  • In the original file I sent try placing a cell.
    First set the angle = 0 scale = 1 in the tool settings.
    Place cell ARROW (this is a Bentley delivered library Sample2.cel)
    Then place DECID
    Then ARROW again.
    Do they all place correctly?
  • Bump - Carl, have you been able to reproduce this phenomena with the original file I supplied?
  • For me all appears to be fine, I have placed as a cell and shared cell using no predefined Workspace/Workset. - ( May be your using a slightly different workflow? )
    Anyone else able to reproduce?
  • This is still occurring.  I deleted my .upf but the issue persists.
    In the image the tools setting does not show how the arrow is actual placed.  When a cell is picked the Active angle always goes to 45, th scale to 100, and place as Shared Cell is toggled on.
    I thought this might be file related but after further experimentation it appears to be related to the Workspace.
