For some reason when I go to place a cell my Active angle is getting set to 45 and my Active scale to 100 and its not file specific.
File Settings
Tools settings displays properly. However cell dynamics show differently
I then toggle the increase angle arrow. This should result in 90 but it goes to 135
I then clicked on the scale ratio lock and the scales switch from 1 to 100.
Frank
I've managed to isolate this a little further. It has something to do with Blocks/DWG's in the cell library search path. If I remove the Block library folders the issue goes away.
