Is it possible to change the line weight of text inside a table cell? I can change the line weight of text that is not inside a table but I cannot figure out how to change it inside a table. Seems to default to 0 and be un-editable. I've looked at text styles and line weight is not an option, I've created a custom element template and tried to tie it to the tables nothing I do has any effect on the text weight.
Exactly like Dimension Lines and Text within the dimension styles toolbox we can define the text line weight different then that of the dimension line, extension line and terminator. The tables already allow us to define the line weight, color etc. It would be nice if we could also adjust the text line weight independent of the table. This would provide a printable table that matches the rest of our drawings.
