The attach Items dialog only allows for 1 field to be displayed. It should be expandable.
Not sure what might be happening with the display of this Attach Item tool dialog.
I am seeing the full list of Property Definitions when I am using this tool.
I have also added new Properties while the dialog is open and it does expand to accommodate the new items.
There is a possibility that this problem could be related to the graphics display on your system.
Are you also seeing this happen with other tools dialog boxes?
Maybe you could supply an example file containing this Item Type for testing.
José
The tool settings should always resize to be large enough to contain the properties of the selected Item Type.
However it will *not* further resize when you expand an array or struct property. That is a known issue - I'll make sure a defect gets filed if one hasn't been already.
David, I get the impression that may be the issue here based on your other thread regarding the Attach Item tool settings. If not, please clarify.
Answer Verified By: DavidG
